moni831
I would make sure the progs are clean wiggle watch gently in its cradle close cradle. I'd restart my cell phone, check for updates for galaxy gear, clear history on cell phone.
Hi guys I*got my gear out the cupboard the other day and it wouldnt charge or turn on when attempted to charge at a socket?? This is a few weeks old. Take the usb off your 3pin plug charger if u have 1 (samsung s4 charger) and plug the gear into a laptop or a desktop and it will start charging slowly. No idea why this works but it does. I think once it goes completely flat it wont charge at a socket outlet. You will all notice that phones and devices take alot longer to charge on laptops and desktops. I think this may have something to do with it. Charge it to 5% on your laptop or desktop and disconnect it and it will start working in your house sockets (charge alot faster). Happy days
I tried everything and didnt expect this to work. I've registered just to say thanks. This really has worked!!!!!Hi had this issue also spent 3 hours trying to figure it out as had just got gear out of its box at very first plugging charger in a quick image appeared on screen then off after that nothing. Eventually being as carefully as possible while gear was in charging dock still plugged in i opened the lid not once did i move gear off contacts but did give sight wiggle then it came to life appears to me its a docking problem of some sort. of course I DON'T RECOMMEND opening lid while charging but thought id pass on what i figured out do at your own risk, I hope this helps others with this issue
Didn't work for me. When i plug it in it says driver installation failed.This works perfectly! Try it, plug the gear into a laptop and wait for some minutes if not up to 30 minutes, it will start working. Mine is working now....great!
