Ok everyone, I'm quite tired researching this issue but I have found the problem and solution.
It's because of the high number of wake locks that's preventing the phone from going into deep sleep when at rest. That's whats draining out the battery so fast.
I also uninstalled the app lock app that was causing a high number of wake locks also. It seems that there is a bug in the OS that's preventing the phone from going into deep sleep mode in-order to conserve battery power.
The fix: Put the phone into airplane mode, reboot the phone, once it's booted up take it off airplane mode.
The results: AMAZING!!!
I ran a couple of tests to prove it.
At 4:00pm two days ago the phone was at 91% 3 hours later (No usage in between) 85%. For me that was a BIG difference. Before this type of reboot I was getting an average drop of roughly 6% per hour.
By doing this I was able to cut that down to a 2% drop per hour. Very nice indeed. The wake lock situation also looks much better as the PowerManagerService was able to kick in now.
Also I was even able to improve on that.
After I had enabled power-saving mode, at 5:00am the battery was at 63%. 10 hours later at 3:00pm, (Again no usage in-between), usually by now it would be dead but it was at 49%. That's 1.4% battery drain per hour. Much better.
I guess if it starts to drain fast again I'll just have to do that procedure again but at least I was able to find a fix and share it with you all. (I don't take credit for it)
Hopefully this gets fixed in the next update.
Here's some screen shots showing the improvement after the reboot. Before I was getting 14h 33m on a full charge. Now it's 1 day, 7hours. That over twice an improvement in battery life. Yeah! I'm loving this phone now!
Let me know if this fixes your power drain issues too.
Thanks everyone for all your replies and suggestions. The android community is a very good one indeed!
