Hello all
I have a problem on my new Note 2.
I cannot answer *some incoming calls (NO RED AND GREEN ANSWER OR DECLINE ICONS APPEAR).
This happens in either the lock screen or on the desktop, makes no difference.
I say 'some' calls, I had 2 calls yesterday fro different locations that I know where from automated sources (like call centres).
I took a call from my other half sometime later with no problem.
Does the Note 2 know they're from dubious sources and not give you the option to answer them? I doubt it..
This is not just that I don't understand you have to swipe the answer icon, the icons never appeared.
The 2 numbers called about 3 or 4 times each, no option to answer them.
I have also enabled the 'answer with home key' feature and this din't answer the call either..
I'm a bit concerned that I'm going to miss a call I really need to take.
Very frustrated, can anyone help me please?
Many thanks.
Many thanks.
