A
AC Question
Sunc problems Samsung Galaxy note 2 just upgraded to 4.4.2
recently there was an update to 4.4.2 that was pushed to my phone (a Samsung Galaxy Note 2). Since then, I have been having sync problems, and continuously get the message "impossible to get the requested authorization" relative to my two google accounts that I had running on the phone
I have tried to delete the google accounts and reinstalling them, first one and then the other, but this has not solved the issue.
I cannot sync calendar, conacts, not to mention that google play does not work.
Can anyone help with a solution?
Thank you!
Thank you!
