The past few days I've been having the problem of the S pen "touching" the screen even though it's pretty far away. Did a lot of reading and saw several others with same issue. I was tossing up removing the button cover to adjust it like some have said.
Anyways it magically fixed itself while I was messing with phone options. Gonna post here so others with this problem can try it. It may have been luck, but just in case...
My pen was in the dock til tutorial
Go to settings, controls, S pen
Select direct pen access
Then click on try it
I pulled my pen out for the tutorial and it just started working like it is supposed to. EDIT: My pen had no cursor for a few seconds but then it just popped up.
My best guess is that maybe the demo checks pen sensitivity. I might have just been luck though.
So if this does work, great! If not then I got lucky and it fixed itself.
