Why does my Note 4 lock on phone calls?
mtbrown19
Active member
Oct 5, 2014
26
Note 4 locks on phone calls
Merry Boxing Day All!
So I currently have the my Note set to lock after 5 minutes however anytime I make a call, even less than a minute, it's locked after. Does this happen to others and can I change this? It's really bugging me...
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
re:
Do you have it set to end phone calls by pressing the Power button? If so, do you also have it set to lock the screen immediately when the Power button is pressed?
mtbrown19
Active member
Oct 5, 2014
26
re:
Checked the settings and it was set to end calls with the power button but not lock. I have changed it and will see if that works.
mtbrown19
Active member
Oct 5, 2014
26
re:
Still having the same issue...phone is locked after every phone call no matter how short. Anyone have any other suggestions?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
re:
Does it look when you make a call using speakerphone with the phone on your desk?
Sent from my Verizon Samsung Galaxy Note 4
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
re:
Perhaps some app going rogue? It isn't a common problem. If it started recently, try to uninstall recent apps.
Also try to clear cache and app data for the phone app
mtbrown19
Active member
Oct 5, 2014
26
re:
Ok so I tried clearing the cache and the data...nothing
Started in safe mode and voila, seems to be working. Now I just need to figure out which app it is! I have moved a chunk of them over to my SD card so I will try booting the phone with the SD card out and see if it still happens. That will narrow things down at least.
Thanks!
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Re: Note 4 locks on phone calls
Nice glad you figured it out
