HELP: How to turn off headphone auto-play?
RTMobile
10
Why would Samsung make it so that music autoplays every time you plug in a headset? Don't they realize that this thing is also a phone, actually it's a phone first, and music player is way down on list for me.
I would love to turn this off!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! Does that happen with headphones that don't have any remote control functions?
SpookDroid
Ambassador
Jul 14, 2011
19,299
555
113
What music player are you using? Mine definitely doesn't do that when using the stock player or Spotify. (Spotify will auto-play IF it's open and I connect it to BT headphones though).
LaTuFu
817
Depending on the app you're using, you can disable this in settings. Poweramp allows you to turn off "Resume on Wired Headset" in the settings menu. If you have PowerAmp as your default player, this will prevent that.
Not sure if you've figured this out yet, either, but the music automatically pauses when placing or receiving a call. So the device definitely recognizes that it has phone capabilities that need to take priority from time to time.
RTMobile
10
I use Power Amp, yes. Just didn't see a setting to turn that off. It happens with every set I plug in, even a mono set, but they all have volume and mute controls.
Let me check Power Amp and get back to the thread.
Thanks!
ohbreeeezy
441
Thanks!
RTMobile
10
LaTuFu, you were right. It was Power Amp. Thank you. I got overwhelmed with the depth of configuration settings in PA a long time ago and never saw this. Love the player a lot though.
Paras Rana1
#MAKE SURE
You uninstall PowerAmp.
Settings > apps > installed > poweramp
BigWizWow
I have a Galaxy S6 Edge
Go to the smart connect app on your phone then press events and turn off the music on the go function
sc98gt
I have an S6 that just started doing this after a T-Mobile update. WTF!
No PowerAmp or Smart Connect app installed. Any thoughts?
smokedog87
