- Apr 23, 2011
- 30,106
- 203
- 63
I bought this case, and while the grip is indeed good, the black rubber portion was very very loose. I was able to push the lip off the top of the case with almost no force. The problem would be if it was ever dropped on its face then the case would provide virtually no protection. Side protection seemed ok.
Just wanted to warn those who were thinking about buying this case, if face drop protection is something you worry about then don't buy it.
https://www.amazon.com/gp/aw/d/B01JM5T1FS?tag=hawk-future-20&ascsubtag=UUacUvbUpU5385366
