This may be a dumb question or asked a bunch before, but, how many edge panels can be selected to utilize?
Does anyone know if EdgeBoard was a choice by default in the selection of stock choices, or did I have to sideload that (which I did) to use Edgeboard?
EdgeBoard is not in Google Play, it is only in Samsung's "Galaxy Apps".
However, Galaxy Apps takes a while to update versions and is still showing v0.5.
The developer has released a newer version (v0.6) that includes:
-fixed landscape not working for all 3 panels
-added options to hide tasks or favs from the main panel to give more room to another list
-increased spacing between items somewhat
-fixed running task list being empty on the main panel
v0.6 is available HERE.
EdgeBoard is not in Google Play, it is only in Samsung's "Galaxy Apps" (which is where the stock choices directs you to).
Should I uninstall older version first or will the .apk just overwrite the old one?
v0.6 will just install over (update) v0.5. Uninstall not required.
However I often find that when I update some panels it is best to do the following to avoid glitches:
Go into "Manage panels" > untick the panel that has been updated > hit your back button (this turns off the panel) > go back into "Manage panels" > re-tick the panel that has been updated > hit your back button (turns it back on).
You may need to reorder your panels after this.
One more question about EdgeBoard: no matter what I do, I can only enable one of the three EdgeBoard panels to appear on edge screen. Is it correct, we can only choose one, if so, why are there three choices to tick? Why is one un-editable?
You can enable all 3 panels of EdgeBoard to appear on the edge screen. I have just tested it again to make sure. If you are up to your maximum panel limit then you may only be able to add 1 instead of all 3. Try unticking some of your currently selected panels and see if it works.
If you are not up to your panel limit but can't select 3 EdgeBoard panels then maybe "clear data" from application manager, EdgeBoard. Then uninstall the app, then reinstall from the apk.
One of the panels is un-editable because it is "running apps panel" so will only show what is running, not customised favourite apps.
