Beut has made it quite clear in a number of threads that anything having to do with battery charge on the 12.2 is likely the solder joints on the battery connector. The solder joints having cracks. It sounds like an easy fix for someone that has the equipment, but difficult for the rest of us.
To date has anyone had their 12.2 solder joints repaired (re-soldered)? If there are some out there that have had this problem fixed by re-soldering can you give the rest of us some info about what kind of place did the repair. If it was an authorized Samsung repair facility could you share contact info? And what did you have to tell them to have this repair done correctly?
I have been all around the Philly area and haven't found anyone that does fine soldering.
Thanks
Thanks
