i cant get to the developer options from that screen.
i also tried what you said about unticking the other boxes and just ticking f reset and autoreboot same problem as before but know it says get pit for mapping.
thanks for your help so far!!!!!!
to enable usb debugging
Go to your Samsung Galaxy S4 Phone settings screen:
Step 2: Click on 'More' icon on the Upper-right to reach "About Device" Option
Step 3: Scroll down and tap Build Number seven times and you see a message that says
?Developer mode has been enabled?.
Step 4: Now, you will see the Developer options menu and select Developer options.
Step 5: Check the USB debugging box under Developer options and you see a message that says
?Allow USB Debugging?
Step 6: You are ready to use your Samsung Galaxy S4 in debugging mode.
in this case you need to a pit file.
sent me the details of your phone
like colour , memory , model ,region network you are using
