I think you'll find this is a bug in Verizon's software. I've been searching for the solution as well, and nobody has an answer, short of replacing the default lock screen with a third-party replacement. GPS and refresh settings have nothing to do with this issue, as my refresh is 60 minutes, and all location services are enabled. A factory reset fixed it briefly (for about 3 days) before it broke again with the next OTA update.
EDIT: I dug into my system settings a bit, and found a possible fix. Scroll to the bottom of the "Manage Apps" screen and look for disabled programs. For some unknown reason, several of my Verizon and stock apps were disabled, including the weather and news services. Turning those back on did the trick. Curiously, "Email" is still disabled, and I can't turn it back on. it also claims to be 0 bytes, which seems unlikely for a program built-in to the ROM ...
