Why is my S3 battery draining rapidly?
Dalton Barham
Help my s3 battery is draining rapidly!
Im running cyanogen mod, on my galaxy s3, i love it - however, it seems to drain battery really fast, so fast that it drains when charging and turned on. it takes a day + to fully charge when off. Ive tried a different battery and multiple chargers, in fact it drained 20% of my friends battery (same phone ) just while booting up :( i've also tried a factory reset, and battery calibration.
Thanks
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: Help my s3 battery is draining rapidly!
That elimminates Cyanogen as a suspect.
That would tend to eliminate the battery as a suspect.
i've also tried ... battery calibration.
Nothing to do with drain - that just keeps track of which apps are using what percentage of the total use.
It could be a bad motherboard, a short somewhere other than the motherboard (charging port board, perhaps), a pinched cable. It has to go on the bench for diagnosis.
smokedog87
