I'm getting half the battery life on 4.4.2, only lasting 11 hours or so instead of the up to 27 hours on 4.3 or 4.2. Will this even out?
How long have you been on the update? If it hasn't been very long give it a few more days and charge cycles. If it doesn't, then consider a factory reset (backup all your data) and see if that improves the life of the battery.I'm getting half the battery life on 4.4.2, only lasting 11 hours or so instead of the up to 27 hours on 4.3 or 4.2. Will this even out?
