Is this possible? Other than turning airplane mode ON and removing the sim card. Thanks
Not getting what you are trying to say here ??? Can you please be more clear about it ?
You can turn WiFi back on after entering airplane mode and the phone will stay off. There are some apps on play store that can break the link permanently, I.e. so that WiFi will not be turned off at all when you turn airplane mode on. Here's one:
https://forums.androidcentral.com/e....chislonchow.airplanemodetweak&token=6DOngdEi
