Galaxy S5: How do I turn off the camera's shutter 'click'?
BubbaMac
9
I want a silent shutter. Even my old EVO let me turn off the shutter sound. I can't see how to do that on the S5. Anyone?
Re: How dod I turn off the S5's camera's shutter 'click'?
I know on my s3 if I turn the volume on silent it will turn the shutter off, idk if it would work on the s5
It should in the camera settings
Sent from my Galaxy S5 using Tapatalk
Thanks for the screenshot... which carrier and country are you in? I don't have that option on my Verizon S5 in the US.
Thanks
Thanks
Did you scroll down? On the AT&T version it's not visible until you do.
I had the click off on my previous phones and silly fools who I'd ask to take photos who mess it up by not waiting until the photo was taken so I turned it back on
I have Sprint and I do not have it either. I did scroll down
T-Mobile version has the option to turn it off. Select settings icon and scroll down just a bit. It's on the bottom right.
Its a law in most states that u cannot turn it off
Sent from my SM-G900V using Tapatalk
Verizon doesn't have that "shutter sound" option either....however..
if you have your call volume on silent or vibrate...than there is no shutter sound.
On the Sprint model at least, if the phone is on vibrate it doesn't make the shutter noise. But there's no option in settings for shutter noise, which would be nice to have if someone doesn't want his phone in vibrate but still wants his shutter sound silent.
Sent from my SM-G900P using Tapatalk
Google "enforced stream silencer". It's should be the first result. Not sure if it works in the s5,but worked on my note 3 and other Samsung phones.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
You have to scroll down on the setting menu.
I'm on Sprint and my phone doesn't have that option either.
Verizon doesn't have that option either....even if you scroll down.
Vector
