Pretty nasty bug with my Galaxy S5 fingerprint scanner, need help.
econoar
4
My fingerprint scanner was working just fine for a week now but tonight it wouldn't pick up my fingerprint anymore. When i went to try to delete out old prints and put new ones in, it won't take my alternate password (although the main lock screen will). When i try to change the alt password on the fingerprint scanner settings screen I get an error that says "an error has occurred with the fingerprint sensor. If it continues please restart your device."
I've restarted and tried everything to no avail. There's nothing online about it yet either. The only thing I can think of is that today I tried to link my Paypal account with my fingerprint. It was an odd process and in doing it Samsung installs an app called "NNL Fingerprint Passport". Perhaps there's a bug with this coming on my phone and overwriting my settings? I've disabled it to no avail as well. I'm pretty stuck now.
No - it's just happened to me. I agree it's a software bug - and my only solution was to do a factory reset and use a pin code to unlock in future rather than the scanner. I did not link with a paypal account and therefore think this is a phone bug.
Interesting. I'm probably going to have to do a factory reset as well. What an awful bug, interesting that it's taking a little time to pop up, I wonder what the cause is.
I have installed the paypal link app today and connected it with my fingerprint and it is still currently working fine for me - Hope I don't develop this issue!
I also have encountered this problem and i have not downloaded anything to do to paypal and this device hasn't registered with the official Samsung webpage so you cant report it either? Really stuck on what to do but if I have to, here goes factory default!
Whilst the problem was solved by a reset in my case I have to be honest and say I am not going to use the scanner regularly again until there's a software update in case it recurs. Suspect a lot more cases will arise as more people use the phone over a longer period of time.
Yesterday my whole S5 operation went on the fritz...pictures took 5-10 seconds to take, Gmail wouldn't send out attachments, calls and texts were delayed and dropped and then last night the finger print reader failed. Likewise, it wouldn't accept my alternate password. I thought I was going to be able to reset it via my Google login, but after trying several times all I have been able to do is access my device and I have no security to prevent unwanted access. Battery life is awful, too, in the past few days. I haven't set any passwords to my fingerprint for other apps, either. I welcome solutions before I do a factory reset, as there's a ton of stuff I will need to back up before that.
I don't remember, but when you set up the fingerprint scanner, does it ask you to verify your password or does it just take the first attempt?
Still no solutions to this that anyone has found I assume? I'm holding off on a factory reset for now and just not using the scanner.
There is no solution other than exchanging for a new phone. My first S5 had the same problem. Factory reset will not fix it. Go and swap your phone out now.
How do you delete old prints? I can not find how to do that anywhere!
just a quick question...are your date and time on the device correct? I ran into a similar issue with not being able to access a lot of things on my S5 couldn't even access google play store or google account!
After a bit of searching I found out this can happen when for some reason Android screws up the time and date it basically freezes up a lot of systems on the phone...not sure if this is your problem but it sure worked for me! Reset date and time!
Hope this works...also, my problem wasn't a Samsung issue but an Android issue
Cheers
I have had this same issue and after a factory reset it has worked well for me
Sent from my SM-G900V using AC Forums mobile app
I am experiencing the same issue, I will hold off doing a reset and hope there is an update.
Sent from my Galaxy s5
I have the same issue since 1 week, unfortunately, my 15 days have passed and I can't return and exchange it. I tried a factory reset from the recovery it didn't work though, Q.Q.
On the locked home screen click Alternate Password option and enter incorrect passwords multiple times. Click cancel after unsuccessful attempts. On the home screen you will find an option to unlock the phone with google account. Use that to unlock the phone and you will be redirected to the Lock Screen settings of the phone. Select any other option to lock the phone like swipe or number lock.
