Android System tanking my battery life! Time to return?
Joe113
878
It can't be normal that Android System is at 26% and higher than my screen (on screen time of 3 1/2 hrs). Any help is appreciated.
Even after a factory reset. Five and a half THOUSAND wake locks, time to return I think?
Sent from a Galaxy 5 light years away
DreamSTi
587
32
Re: Android System tanking my battery life!
ummmm 1 day 5 hours with 20% life left on a single charge and you see a problem? There is NOTHING wrong!!!!!!!!!!!!!!!!!!!
sirmaru
264
That means you haven't used the unit much in that time period. The screen is only used when you are actually using it.
Joe113
878
Yes bc I got these same stats with my GS4 so yes I do see a problem. And I was using my phone a moderate amount.
talyler
7
It's normal, here is mine right now.
SanDeggo
53
My battery life is about 7 hours while streaming movies on my phone continuously. How fast are we talking about that your battery is draining in real time not by what you think is happening based on what Android Battery Usage says is happening?
Joe113
878
I ended up getting 1 day 10 hrs with 4 hrs 10 min of on screen time. Not thattt bad, but still not what I was expecting.
Joe113
878
Five and a half THOUSAND wakelocks... this can't be normal.
Radnor
Solution: Turn off Google's Location Reporting.
Settings > Connections > Location > Google Location Reporting > Location Reporting: Off for this device
Joe113
878
That's the first thing I do whenever I flash a ROM. So needless to say that's been done lol. Can someone else with a GS5 confirm that it's not only my device doing that and it is just KitKat? Just using GSam with it's "root companion" app gives you plenty of battery stats/info! I'd really appreciate it.
dwd3885
736
25
I can tell you I returned one S5 and the next one is the same thing so there's that.
erasat
2,590
There's nothing wrong with the devices, like I've mentioned before, since kit Kat my s4 began with this, before that, Screen was always sbowing 60 to 65 % , the same day of the update it began having the Android system at the top, I noticed some decrease on battery but it maybe related to other things that I never adjusted, now fast forwarding to s5, it came with kit Kat so there's no way on knowing how could it be with out it, but even like this, my screen on time are insane, for the past 3 days after making all my normal adjustments, I'm averaging 5.5 - 6 screen on hours, with lte, wifi and Bluetooth for my gear 2 neo all the time. Today, I'm almost at 7 hours of screen on time, and it was unplugged last night at 10pm.
If you want to see what I'm saying here, just download Gsam Battery app and you will see that it shows threw normal usage we all Galaxy Users were used to before kit kat, so I'm guessing that something changed with kit Kat that caused issue with the built in battery usage app on the galaxies.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Not that bad? That is great life.
Honestly I have to ask.. What phone were you using before where you got better battery life? I am curious as to where your expectations are coming from.
Sent from my T-Mobile Note 3 using AC Forums.
Kevin OQuinn
AC Team Emeritus
May 17, 2010
9,267
496
I don't see a problem with your battery life at all.
I wonder if you never looked at those details in gsam if you'd think that there was a problem. :)
Sure, you can turn off location services and your battery life will probably get a little bit better. That should be expected since you're turning something off.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Joe113
878
S4
DreamSTi
587
32
You people who think you have a problem that are getting over a day on a single charge are bat**** crazy! ITS NORMAL!!!!!!!!!!!
LMychajluk
59
As I type this, I'm at 79% in almost 8 hrs, with just some browsing and email on my commute into the office this morning. With my S3, I'd be closer to 25% about now, and lucky to make it home at the end of the day without recharging. Normal or not, I'm not complaining.
I did have an issue the other day where the phone felt warm, and was using juice faster than normal. The battery screen only showed Android System and Android OS, no other apps (weird...). Put it on the OEM charger overnight and re-booted in the morning as soon as I took it off and it's been fine ever since. I'm assuming the OP is using the OEM USB 3.0 charging cable?
cloudsofmana
