How many water damage indicators does GS5 has? Where were they located on the device?
If you remove battery you will see little square next to serial number and the battery have it as well
Normal one is pure white some phones have purple x
Red square is damage indicator
Do you have red square in the phone and the battery
Ok let's start now. You sure that back cover fully sealed 100% ? And usb cover fully closed ?
What case was it ?
Spigen tough armor.
Interesting... did you wash your phone before and didn't open your cover If so water went in the device you did it now again
I think your rubber has changed did you play on the rubber ?
No, not at all.
Can you make picture to your s5 back cover
See this holes? That's whu
That wasnt a whole.
