Quick Charge 2.0 Dual USB Car Charger
aznicktwit
20
Quick question, preordered 2 S6s, one for me other for spouse and now I need to get car chargers (for 2 cars). I see a lot of dual port quick chargers on this site and amazon however I can't tell if both ports can do the quick charge at the same time or is it just one phone can quick charge while the other is regular charge. I realize that the increase in power output may necessitate having only one port perform quick charge at a time but am curious if one exists to do both phones?
I haven't seen one.
Sent from my Verizon Samsung Galaxy Note 4
Been using this fast charger from Verizon with the Note 4 and it works fantastic. Even has a push button LED light on the end.
This is a Qualcomm 2.0 fast car charger.
I haven't seen any that specifically say quick charge 2.0 but I ordered this one and it's probably pretty close if not exactly the same. Can put out 4.8A total between 2 phones. http://www.amazon.com/gp/aw/d/B00DD...ag=hawk-future-20&ascsubtag=UUacUvbUpU4325273
This does not support quick charge 2.0. It does have 5v/2.4a,but not sure if the s6 can take advantage of it, or if it would use less. On my note 4, these support around 5v/1.8a max.
I'm not clear on the tech of the quick charge 2.0, is the maxboost compatible with that and can both ports output quick charge at the same time?
Looked around and I can only find one with 1 port or they have multiple ports but only one of the ports is a Quick Charge one. I just think having two QC ports would add too much heat into a small car charger probably.
I have the maxboost 4.4 charger off of Amazon but can't post link cause I'm new
Cleaned up some posts. To clarify, it DOES NOT support quick charge 2.0.
Okay thanks for the info, guess I'll have to buy 4 standalone chargers
If you are still interested, iVoler had a new Dual Quick Charge 2.0 Port Car Charger. I ordered their wall charger and they sent me a coupon code which take $6 Off. The coupon code is QCDU5OFF
Has anyone tried the iVoler Dual Quick Charge 2.0 Port Car Charger? I am wondering if anyone has real world experience charging two Qualcomm Quick Charge 2.0 phones at the same time.
