What is the best Micro SD card for the Samsung Galaxy S7/S7 Edge?
anon(9842641)
75
looking to buy best Read/Writes speed micro sd for my samsung galaxy s7 edge pre ordered in att. so which micro sd has optimal performance with out bottle-neck to use on new phones , i dont want to buy highspeed cards if that s7 cannot handle those high speeds .
thank you
Re: Best Micro SD card for SAMSUNG GALAXY S7/ S7 EDGE
thank you
Not the best read/write speeds, but this 200GB microSD card is pretty awesome and it's only $79. I ordered one yesterday: Amazon.com: SanDisk Ultra 200GB Micro SD (SDSDQUAN-200G-G4A): Computers & Accessories
Does that 200 gb record 4k?
I'm wondering if this snazzy UHS-II thing will work with the S7 to its fully rated speeds or whether the phone can only take advantage of UHS-I cards;
Lexar Professional 64 GB Class 10 High Performance Micro SDHC UHS-II Memory Card with Card Reader https://www.amazon.co.uk/dp/B00U0XG...ag=hawk-future-21&ascsubtag=UUacUvbUpU5028814
I don't believe it will take advantage of the faster UHS-II architecture as no sources I have found say the S7 has this capability. This card you referenced will still work, though, at the UHS-I U3 speed ratings (minimum of 30MB/sec write).
It will be able to keep up with 4K video recording, as all cards with a Class 10 rating will (minimum of 10MB/sec write).
Samsung 64GB EVO Class 10 Micro SDXC Card with Adapter up to 48/MB/s (MB-MP64DA/AM)
I cant post links in this forums yet . So that is the item i found in amazon
64gb
U1
Class 10
48mbps
And only 17$ sweetspot
I found this , its rather cheap and also 64gb which is enougj for me i think
i found this on amazon for 24 $
256 GB
class 10 U1
is it fake ? or i found an awsome deal ?? LOL :mad:
Using 128gb SanDisk that came free with LG G4. Working fine. No reformatting needed.
If you want cost for performance the samsung pro 64gb you can't go wrong with it. If you don't care for price and want slightly faster speed you can get the samsung pro +. The fastest card is the sandisk extreme pro however i have heard that samsung has issues while using sandisk cards on several forums and I don't want to risk it.
The one linked below is the one I purchased, and I know the reviews say that they received a fake on, but Amazon sells this card directly, I called them and the rep assured me their Samsung IT department has checked their stock for fakes since the incident and followed up with this email.
Hello Jason,
We want customers to purchase with confidence when buying collectibles on Amazon.com. To help customers make purchasing decisions, sellers are able to display whether a product comes with a Certificate of Authenticity. If a product has been authenticated, the seller can also provide the name of the authenticator and an image of the certificate.
I can confirm that the item you purchased is authentic and Samsung IT specialist already checked the inventory that we have on our warehouse.
You can return most items sold and fulfilled by Amazon.com in new condition with all original packaging and accessories within 30 days of delivery for a full refund.
http://www.amazon.com/Samsung-Class...ag=hawk-future-20&ascsubtag=UUacUvbUpU5028921
How about this pny u3 turrbo performance 64gb for 24$
The Samsung EVO+ is also a really good bang for the buck with great speeds and not at U3 prices.
Thanks xoxomoax , i think i will go for the evo + 64gb atlast
I think you should go with the regular pro, the read speed is slightly faster, and the write speed is a lot faster. very important for burst shots. Here is a reviewer on amazon who reviewed a bunch of sd cards
Test Setup:
Lexar Professional workflow UR1 microsd card reader was used for all tests except when noted
CrystalDiskMark 5.0.2 x64 was used to produce all the test results and was set up with 2 passes and 100MB read/write size
All cards up to 32GB are formatted as FAT32 with 32KB allocation unit size, all 64GB cards are formatted exFAT with 128KB allocation unit size
Test Results (Numbers are Sequential Read, Sequential Write, 4K Random Read, 4K Random Write in MB/s, speeds greater than 10MB/s were rounded to the whole numbers)
16 GB Alphabetically
Lexar 633x** -- 88, 25, 8.7, 1.2
Panasonic U3** -- 93, 42, 11, 0.7
Sandisk Extreme Pro -- 95, 80, 7.6, 2.6
32 GB Alphabetically
Delkin U3 -- 93, 59, 11, 0.6
Kingston 90R/80W -- 93, 58, 11, 0.6
Lexar 1000x -- 90, 57, 10, 1.4 <== the listed product
Lexar 1000x with Bundled Reader* -- 148, 60, 10, 1.4
Patriot EP -- 90, 35, 10, 0.6
PNY Turbo Performance -- 91, 55, 6.9, 0.9
PNY Elite Performance Lime Green -- 94, 55, 7.4, 1.0
Samsung Pro gray -- 92, 82, 10, 3.6
Sandisk Extreme Pro -- 94, 87, 9, 3.0
Sony up to 95MB/s -- 91, 51, 4.8, 0.9
Transcend Ultimate 633x -- 93, 85, 8.1, 1.4
64 GB Alphabetically
Delkin U3 -- 94, 27, 13, 0.3
Kingston 90R/80W -- 94, 25, 13, 0.3
Lexar 1000x -- 92, 56, 12, 1.5
Lexar 1000x with Bundled Reader* -- 153, 66, 11, 1.7
Patriot EP -- 81, 22, 11, 0.6
PNY Turbo Performance -- 92, 54, 6.9, 0.9
PNY Elite Performance Lime Green -- 92, 54, 7.5, 1.0
Samsung black -- 82, 20, 8.8, 2.1
Samsung Pro gray -- 90, 80, 10, 3.5
Samsung Pro+ *** -- 92, 86, 10, 5.3
Sandisk Extreme U3 -- 92, 88, 5.5, 0.5
Sandisk Extreme Plus U1 **** -- 92, 58, 10, 2.8
Sandisk Extreme Plus U3 -- 92, 88, 9.4, 2.9
Sandisk Extreme Pro - 97, 91, 10, 3.0
Sandisk Ultra ***** -- 46, 16, 7.0, 2.1
Sony up to 95MB/s -- 92, 49, 5.2, 0.9
Transcend Ultimate 633x -- 93, 83, 7.3, 1.4
128 GB Alphabetically
Lexar 633x -- 78, 28, 3.3, 1.4
PNY High Performance -- 81, 22, 5.4, 0.9
Samsung EVO+ -- 82, 26, 5.9, 1,2 <== the listed product, different capacity
Sandisk Ultra -- 92, 19, 6.4, 2.4
Jpdaballa uh can i know wich pro u r talkin abt?
Samsung pro or sandisk in that review??
Vector
