Now that you have made the move to the S7 edge, how do you feel about the decision? Do you feel it was worth upgrading? Do you see a big difference between the two (not talking about the obvious screen size difference)?
I am really happy with my S6 edge, with the exception of battery life. I can't even make it through a full day of work without putting it on the charger, and I only use it on my lunch break. That would be my main reason for upgrading. Thanks for any input!
