question about nova on my S7 edge
thegame161
1,298
Question guys is there a way when on nova to click the page you want to view instead of scrolling through each page. I know on touchwiz you can click the page indicator under the apps
Javier P
Ambassador
Feb 21, 2014
19,480
3
With Nova you can create a shortcut to 'jump' to any page. Long press on the screen, tap on widgets, drag Nova Actions to the home screen and select 'jump to page'. If you have many pages you can create a shortcut for each one and put them in a folder using numbers as icons from any icon pack.
thegame161
1,298
many thanks for this, i just remembered last time on nova you could do it through the indicator under the apps.
Non
