So I'm a new Edge owner, great great device with one major caveat. At the gym I use the phone with headphones to listen to music or podcasts. On the treadmill, after about 5 to 10 minutes the volume just starts shooting down till it's off. I can take it out and raise it back up, but then within 10-15 seconds afterwards it's lowering itself again back down. I've even taken it out and turned the screen on and just held it without touching any of the screen, and also use a towel to make sure there's no water or anything on the screen, and you can just watch it magically turn the volume back down again, as well as randomly select and open apps on that side of the screen. It's, to put it lightly, incredibly annoying.
I think it has something to do with the running. I've noticed that's when it acts the worse. Is this a common thing? Should I just return this thing for a new one?
