Well I know we're all excited to get our phones but with all the discussion on possible dislikes like display/finger print scanner, size height???
Who is returning and why?
I'm on the edge about returning it........
I might get the S8+..... I'm not sure yet....
More S8+s were sold than S8s. I think it's because they line the bigger screen but not much bigger size. That seems to be what many have said in posts and reviews.I ordered the 8, havent received it yet but thinking I should have order the plus. any regrets for the regular 8?
Cell reception may get you, my iPhone gets better reception then the note 7 i had and i expect the S8 will be the same.There's only 2 things that could make me return the device and I don't think either will be an issue:
1. Cell reception where I work. I have Verizon and my iPhone 6S Plus gets good reception here. If for whatever reason the S8 doesn't that would be a deal breaker.
2. Camera - specifically recording video. Most sample videos I've seen shows some jitters or frame wiggle when panning across wide areas. My iPhone 6S Plus is perfectly smooth in this regard. I'm sure the S8 takes better still pictures than the iPhone 6S Plus but I take a lot of videos and if I can't record smooth videos with the S8 that'd be a deal breaker also.
