It was fine when I bought it at launch. I use SVoice for almost all features. Anyone has similar experience and solution?
Sent from my SM-G900T using AC Forums mobile app
Good advice regarding the amount of moisture, but I would think it would not be an issue since it should be water resistant, oh well. The problem started a week ago, so whatever possible moisture should be gone.
Great advice with the rubbing alcohol. Hopefully the speaker in the next generation is placed elsewhere to prevent sweat accumulation. I no longer own the Gear 2, now have the Gear S, same issue unfortunately.Put some rubbing alcohol on a paper towel and clean the speaker/mic area well. This will clean out the speaker/mic section. I run 3-4 times a week, so I clean it with water most days, and alcohol in the one spot 1 every 2 weeks. Every time I noticed a garbled speaker, this clears it up.
