Hi do you use a screen protector on your smartwatch's I do but just seen a Samsung how to guide and they say don't use a screen protector ?? Don't know if I should take it off ?? What do you think?
I think this is the same as screen protectors on mobile phones - it's all preference and there really is no right or wrong answer. If it suits you and there's no issue with visibility, then keep it. Otherwise, if you feel it's not necessary then remove it.Hi do you use a screen protector on your smartwatch's I do but just seen a Samsung how to guide and they say don't use a screen protector ?? Don't know if I should take it off ?? What do you think?
I am currently using the Skinomi screen protector on my Gear 2 Neo. I have experienced no issues in regards to performance. I haven't noticed a single touch not recognized.
That being said, I'm not totally sold if I want it on, or not. After about a week, it is developing some type of weird texture into the protector that I can only describe as "wormlike" lines underneath it. Unless you are in direct light, you don't see them. And, again, it doesn't affect the performance of the watch, but I can feel them as I slide my finger over it.
I'm going to change out the protector tonight and give a second one a shot, but if this one doesn't fair better, I may not use one.
we have the same issue with wormlike lines (great description, btw!!) with our Armoursuit shields. Not only that, but one day weeks after application my wife's shield had a bunch of tiny bubbles on the top 1/3 of the screen. I'm not to crazy about the shields.
I've ordered one from Ebay. Got a gear1 instead of the one I ordered. So for now only 3/4 quarter's of the watch is protected. Waiting for the seller to send me a new one. If you order one from the Internet make sure they will get that you need one for gear 2
Sent from my SM-N9005 using AC Forums mobile app
I have tried two types one works for me as Amazon.com: Skinomi® TechSkin - Samsung Galaxy Gear 2 Neo Screen Protector (6-PACK) Premium HD Clear Film / Ultra High Definition Invisible and Anti-Bubble Crystal Shield with Free Lifetime Replacement Warranty - Retail Packaging: Computers & Access
the other sucked! and I don't recommend Amazon.com: iSmooth Samsung Galaxy Gear 2 Neo Screen Protector - Retail Packaging - Clear: Cell Phones & Accessories
Hard crystal types? Can you give me a name so I can have a look please they sound good hopefully our smartwatch's will get them soon
