zaydabarber Well-known member Jun 17, 2013 308 0 0 Visit site Aug 15, 2014 #1 Gear 2 at&t galaxy note 3, tab 2 10.1
NoFaQ Well-known member Mar 26, 2014 203 0 0 Visit site Aug 15, 2014 #2 zaydabarber said: Gear 2 at&t galaxy note 3, tab 2 10.1 Click to expand... Are you talking about finding the apps for the Gear 2? You have to go to Samsung Apps through the Gear Manager, and not through the standard Samsung Apps.
zaydabarber Well-known member Jun 17, 2013 308 0 0 Visit site Aug 16, 2014 #3 Yes I look I dont see it for the gear 2 Posted via Android Central App
JimSmith94 Well-known member Oct 3, 2011 664 2 18 Visit site Aug 16, 2014 #4 zaydabarber said: Yes I look I dont see it for the gear 2 Posted via Android Central App Click to expand... Have you installed Gear Manager from the main Samsung Apps? Then you can go into Gear Manager and select Samsung Apps for the Gear 2. They made it as complicated as they could.
A anon(2383976) Well-known member May 10, 2012 343 1 0 Visit site Aug 18, 2014 #5 There's an easy way. Touch the notification (from drop down) that you are connected to Gear 2 and it launches Gear manager.
