1. Mastiha's Avatar
    Coming from the Pebble, the vibration on the Gear Live is pretty weak.
    Is there a way or setting to increase it?
    07-07-2014 02:33 AM
  2. itinj6's Avatar
    The Galaxy Gear and Gear2/Neo defaulted to max vibration setting. The weak vibration was one of the main complaints about those devices from Samsung. I'm guessing the Gear Live is similar with respect to internal hardware. I hate to say it but that's probably as good as it gets. I hope I'm wrong though.
    07-07-2014 11:16 AM
  3. jschu22's Avatar
    I find it to be similar to the Gears Ive owned, which has worked for me. Not necessarily enough to wake someone from a sound sleep but has worked fine for me otherwise.
    07-07-2014 12:16 PM
  4. Curtis Martin's Avatar
    I don't seem to be getting any vibration at all.
    Is there a setting somewhere (can't find one) or is it more likely that mine's defective?
    07-09-2014 03:27 PM
  5. phatboy29m's Avatar
    Yeah the vibration on this thing is almost nonexistent. I'm missing maybe 90%of my notifications. I own A Gear 2 Neo and I don't have this problem with that device.
    07-09-2014 04:33 PM
  6. Fedway's Avatar
    Maybe its just me, but I wouldn't want the vibration to be any stronger. It's plenty strong enough to get my attention but not so strong as to be noticeable by others around you.
    07-10-2014 02:02 PM
  7. mush10's Avatar
    I think it is too light as well. I constantly miss notifications as well.
    Sent from my Nexus 5 using Tapatalk
    07-10-2014 05:15 PM
  1. Andriod updat 4.4.2 Screen Mirror not working
    Last Post: 09-25-2014, 05:52 AM
  2. S5 back and camera not aligned properly
    By briankim288 in forum Samsung Galaxy S5
    Last Post: 09-18-2014, 07:53 AM
  3. Android 2.3.6 vibrate on file selection
    Last Post: 07-07-2014, 06:01 AM
  4. Replies: 0
    Last Post: 07-07-2014, 01:10 AM
