For those SUCCESSFULLY receiving notifications on Gear S in stand-alone mode
Hi there,
Apparently there are at least some of you who are successfully receiving notifications from your favorite "to do" / tasks app when your Gear S is in stand-alone mode and not connected by bluetooth to your phone. I really need to know please and thank you -- what task/to-do app(s) you're using and what your phone & watch settings are that makes you successful with this.
It's my understanding that when the watch is in stand-alone mode the notifications are supposed to go through either your carrier or the Samsung network (not sure which - maybe both?) and wind up on your watch and that this does work for some but it's not happening for me. After my first factory reset this function did work briefly but after a couple days it stopped working.
I've spent countless hours factory resetting my phone (within the phone) and hard resetting (manually) a minimum of 6 times. I've tried about 8 different calendars, to-do and task apps (some of which don't even work in bluetooth mode). I've tried messing with every possible setting I can find on my phone. Due to some other issues with my backup app, I permanently lost backups and settings so this has been a real frustrating experience for me. I've taken watch #1 back to my VZW store (30 or so mi away), the clerk could not make it work either so they swapped me for watch #2 and I said I'd go home, reset my phone and try again. This is the one and only time that the stand-alone mode worked but only for a couple days.
In desperation I even stooped low enough to try Google calendar/tasks/sync apps and I'm one that really wants as little to do with Google on my devices as possible. This didn't even work.
I want to keep the watch so bad I'm in "I have to find a way to make this work!" mode (totally obsessed!) but it's beyond ridiculous how much time I've spent in my attempts over about the last almost 3 weeks since purchasing the watch.
I've Googled for ways to fix this and found that some places report the same issue and that this IS a problem with the watch although I don't know if/or how aware Samsung is of the problem. If this is true, Samsung sure didn't test this function very well before they cut it loose on the market. Some folks have decided to keep their watches and hang in there for an update that will cure the problem but we all know how long that can take and we also know that all that's not working is made to work in an update.
What's going on with me is definitely a good selling point for the "don't buy until they get the bugs out" school of thought. "Buyer Beware" comes to mind.
Thanks so much for all input and for listening to my adventures.
Deb
Hi there,
Deb
