All:
I am now officially releasing part one of a two click root method for both the Sprint and Boost Samsung Replenish phones. To install this custom kernel, you must verify your phone meets the following criteria:
1. You have a Samsung replenish on Sprint and Boost networks.
2. You DO NOT have phoenix ROM installed (phoenix ROM uses the EXT4 file system, and this custom kernel release is for the Samsung RFS file system).
3. You have the most recent update from your carrier. To locate your version, go to settings->About Phone and scroll to "Build Number". Look for "GINGERBREAD.FA19 (sprint) or GINGERBREAD.FB03 (boost). If you don't have either of these, DO NOT INSTALL this kernel.
4. You have the clock-work-mod recovery image installed. If you don't look around this forum and you can find instructions on how to install it.
If you meet the above criteria, you can install my custom kernel as follows:
1. Download the update.zip file (attached below) and save it to the root of your SD card.
2. Reboot into recovery mode. To do so, hold down the "U" key while powering up your phone.
3. Navigate to the "Apply update from SDcard" option. This will automatically install the custom kernel from the update.zip file you copied to your SD card in step one above.
4. Reboot.
You will now have a new splash screen that will confirm you are now using the new kernel.
This kernel allows you to overclock your CPU (with the appropriate app installed - I recommend CPU Cruise Control which you can find on the market - the free version should work just fine with this kernel). It also allows you to select different CPU governors which provide much better battery savings than the stock governor. So basically, you should expect better battery life (some folks have suggested they get a 2x improvement on battery life).
This kernel will also root your phone, however to get full use of being root, you will need to perform some other steps. I will create a one click method to complete these steps and update this post in the not to distant future. Till then, enjoy the longer battery life!
And finally, I'd like to thank my Boost Beta testers (ciscogee and 34) who were willing to test my custom kernel on their phones.
Please address any questions to this post - I typically check often.
