Volume plus
elvis1935
183
4
Yes it don't work. If you want to make it louder download eq and set that up the way you want it to sound it will make everything on your phone louder.
reagan247
228
26
I use it, and even got the paid version because it does such a great job. Anyone that says it doesn't work, hasn't read the instructions to properly set it up. It makes a huge difference.
elvis1935
183
4
I know how to use it pal it worked on my evo3d and anyway it's not that great of an app anyway the eq app that I told the guy about last week is better you can set it up just the way you want it for different music or just everyday use.:)
mranderson41
Active member
Aug 2, 2010
34
3
Maybe I'm dense but I've searched for this eq app in the market and can't find it. Searching for "eq" brings up a load of apps but I'm not sure which one you're referring to.
