Heelp pleasse! Samsung Galaxy Note 2 will not lock!
Simone Lam
3
So I have gone onto settings-lock screen- and then put in a screen lock. I also have "lock instantly with power key" ticked and I have set it to lock automatically. I have been trying to fix this with all different settings all day but for some reason, when I click the power button on the side of the phone to lock the screen, it doesn't lock! The phone screen goes black (as it should) but then to unlock, it doesn't ask me for a password. Am I missing something here?? Surely this should be simple. Everyone can use my phone..
(Another note: If I'm on my phone and I open up my messages in the pull down notification menu, it does ask me for a password, but this is the only time it does)
I can't find anything on this online. Someone please heelp!
Victor R
63
I know it sounds simple. But, did you restart your phone?
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Mickeywdw1254
Active member
May 17, 2010
31
Did you adjust the "secured lock time" settings?
JayRatliff
70
Just lower your timer to 15 seconds, it will get you by until the update. Not finding any other references to this occurring commonly.
Just tested mine and it works fine, however, I am using the pattern lock, not a pin code lock. You might try the pattern lock and see if it will work.....
Simone Lam
3
Ok so I've tried a pattern, password and pin lock.. with no success.. I've tried the "lock instantly with power key" and I've changed the timer to screen lock in "15 seconds after screen automatically turns off". I've called Samsung helpline and they told me to switch it off and take the battery out- but that didn't work either..
@acbuescher - let me know if you find a solution! Thanks for the replies
JayRatliff
70
You could hard reset your phone if it is a software issue occurring randomly.
1. Backup all your data
2. Hard reset your phone Hard Reset Found Here
3. Restore your data
Not sure how savy you are, but you cold flash the stock ROM back in an attempt to fix the problem.
inspectagadget1973
57
If it was me is take it back for a new one
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
chloe s
Hey my phone was doing the same thing. I went to security and screen lock then put it on swipe and pressed home. Let me know if it works for you! :)
GarTheConquer
Same thing is happening for my Note 2. Got this lovely device yesterday and I still can't get the screen to lock more than once. I tried the battery removal. I am going to take it back tomorrow. :'(
GarTheConquer
I'll try that today and report back. I read somewhere that I must wait until some kind of setup is complete before signing in with my Gmail account because of this"no lock screen glitch."
Steve Parkinson
Here's what you do.
1. Settings > Lock Screen > Screen Lock then set your pin
2. On the same Lock screen setting screen > Secured lock time > Instantly with the power key or when the screen times out
Done. When your screen times out or you press lock key. Press lock key again and it'll ask you to enter the pin.
As stupid as it sounds, this screen lock is considered "Secured lock" which requires another timing set up regardless of your display time out settings.
p.s. You don't need to lower this secured lock by 15 seconds. You can have it locked instantly or whenever your other display time out setting kicks in. This feature is to allow people to not having to put in the pin every time their display is turned off, but only if it's off by X minutes.
dodong27
245
Mine is working perfectly fine.
Lock screen and password feature works.
Maybe return it and get a new one...
Varun Singh
lol exact same thing happend wid m also i freaked out as well..
just uncheck lock immedtialy wid power key ,
and go to lock automatically> immediatly
and tada it will be all normal :D
hope this works
rms2005
8
3
I was having the same problem and after playing with it and many apps it turned out to be something with gosms, once i uninstalled go the lockscreen worked fine, reinstall it and the problem comes back. Been with handcent for about 24 hours now and not one problem.
dodong27
245
I'm guessing her lock screen is working now..???
