Results 1 to 6 of 6
- 03-15-2013, 12:22 PM
Thread Author #1
Issue with Keyboard not opening after device restart
Every time I restart my T Mobile Note 2 when I go to type an email or text of any kind it take the keyboard a couple of minutes to open. This just started within the past couple of weeks. I am using the swipe keyboard on a daily basis, but still have the Samsung default installed as well. Has anyone else experienced this issue or know how to fix it?
- 03-18-2013, 01:02 PM #2
Re: Issue with Keyboard not opening after device restart
- 03-18-2013, 01:19 PM
Thread Author #3
Yeah I've posted several places, and your my first response. I thought it might be from swype beta even though it has ran perfect for months, so I uninstalled it and tried the stock keyboard and had the same issue. It's very odd.
Sent from my SGH-T889 using Android Central Forums - 03-18-2013, 02:32 PM #4
- 03-18-2013, 02:38 PM
Thread Author #5
- 03-18-2013, 03:49 PM #6
I'm thinking that there is a process (or worse, a widget) that is tying up the keyboard resource (that's why it doesn't display instantaneously). if you can isolate that process or possibly a widget and get rid of it, that would do it. Otherwise, I'm afraid the only thing I can recommend is a reset.
Issues with keyboard/typing after update
By tbirdie in forum Sprint Galaxy S3Replies: 6Last Post: 03-14-2013, 07:33 AM -
Blue tooth connection issues with keyboard
By slwerner in forum Motorola XoomReplies: 0Last Post: 08-15-2011, 11:30 AM -
Market not opening after Das BAMF 2.1 install
By JeffreyVest in forum Thunderbolt Rooting, ROMs, and HacksReplies: 6Last Post: 06-23-2011, 02:58 PM -
How I fixed my issue with LED not working on DROIDX after Gingerbread upgrade.
By Sean McGinty in forum Motorola Droid XReplies: 0Last Post: 06-09-2011, 07:54 PM -
Ringtones not set after I restart or power down my phone.
By Chilly818 in forum Verizon HTC ThunderboltReplies: 1Last Post: 03-30-2011, 03:09 PM
Reply
