Is there a way to put the mobile data toggle into the notification bar?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
I have a verizon note 2 and it has the mobile data toggle. My friend has the tmobile Note II and he didn't have the toggle. Is there any way to add it to the tmobile notification bar?
Sent from my Verizon Samsung Galaxy Note II
Sashreek
Active member
Jan 1, 2012
28
Go to settings-> display-> notification panel and from there you can add the toggle for mobile data.
Sent from my GT-I9300 using Android Central Forums
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
I tried that, and didn't see that option in my friend's tmobile variant. It is running 4.1.2 if that makes any difference
Sashreek
Active member
Jan 1, 2012
28
My phone is also running on 4.1.2 so that should not make any difference.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
I don't know why, but I looked in the display menu under notification bar, and it did allow customization, but did not have the option for mobile data toggle on the tmobile Note II. My Verizon Samsung Galaxy Note II did have the toggle
Sashreek
Active member
Jan 1, 2012
28
I think it's better if you download any mobile toggle widgets from play stoe.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Notification toggle works, I just prefer a stock method to add it to the bar that's already there.
bno762
Active member
Sep 29, 2010
35
Wouldn't the Wifi toggle do the same thing? Or are you trying to turn mobile data down from 4g to 2g?
Internet_Tough_Guy
147
no, he's trying to just turn the mobile data (your carrier's network access) on/off. Wifi is there as an option the notification panel, but not mobile data.
bno762
Active member
Sep 29, 2010
35
So then if he wants to turn mobile data off he should just use the airplane mode, right?
k425
81
10
Download Widgetsoid from the Play Store. This is exactly what you're looking for! As you can customize it to look exactly like the toggles in the notification bar!
https://forums.androidcentral.com/e...store/apps/details?id=com.jim2&token=I2IFAqxS
Here's a screen shot...
cTrrftYS
http://db.tt/cTrrftYS
Sent from my SPH-L900 using Android Central Forums
msndrstood
1,619
7
38
Internet_Tough_Guy
147
Sure, if you turn on Airplane Mode it'll turn all radios off, which includes cell reception and network data. Some people are on a restricted data plan, so the general rule of thumb is, if you're not browsing the intenet or using apps that require data, then you should turn your network data off, but you still would want your cell reception on to receive calls and text.
So I think you're really confused. I'm not sure if you're just trolling us or really don't know what the difference between data accessed via wifi and data accessed via carrier network?
msndrstood
1,619
7
38
If you use Airplane mode, you won't receive texts or phone calls. I just toggle mobile networks and wifi off, but leave the cell radio on so I can receive calls and texts during the night or whatever. Depends on what is important to you. I need to be able to receive texts from family so I leave the cell radio on at all times.
Hope this helps.
What?! ...I'm msndrstood.
via Gnex
bno762
Active member
Sep 29, 2010
35
Not trolling. Just asking questions. Yes, I know the difference. It just didn't click that the op needed to turn off mobile data and still use the cell.
cloudsofmana
