a few recommendations:
1. you need to completely shut down all your usage and rerun this diagnosic overnight. Your usage of apps and the phone is cluttering the results. So charge your phone up completely before going to bed, then put it in Airplane mode or just have the cell reception on (turn all other data & wifi radios and apps off), and let the diagnostic/logger run overnight. Then give us another screenshot.
2. what's pulse? Whatever it is, don't actively use it while you run the diagnostic overnight. If pulse is passive, then let it go, it might be the culprit too.
3. based on the link I provided earlier, you can start disabling stock Samsung and T-Mobile bloatware apps, and other suggestion mentioned in the thread.
Yeah I'm not going to root. I'll make sure to take another screen shot tomorrow. Since I already used my Note 2 for about 20 mins today. Only for Pulse but I understand that can mess up the report.
I just want to thank you for you're help. I'll make a reminder to take a screen as soon as I wake up.
Also when you disable bloatware you can re inable it right? I think I'll disable the Google Music and Play Books, ect.
I did try one thing though. Last night I deleted Google play Services cache and the Data then I uninstalled it. Then Google hangouts popped up saying I need Google play services, ect. So I reinstalled it and it seems it's using a little bit less battery overnight.
When I woke up today I looked at my stock battery monitor and it wasn't above Android OS. Most ever other time it's far above it. This time Google Services was 2% below it at 28% and Android OS was at 30%
But I did restart my Note 2 and from all the testing I've done when I restart my Note 2 before I fully charge it. I always get better battery life. Ever since 4.1.2 anyway. Back on 4.1.1 I could leave my Note 2 on for a week and everything would run as normal.
I also have screen shots back from 4.1.1 with my battery going on 5+ hours of on screen time with 40% battery easily left to go.
OK I'm ranting now sorry about that and I'll get back to you. You can always PM me as well and I'll get back to you as soon as possible.
Again, thanks for all the help.
Sent from my SGH-T889 using Tapatalk 4 Beta
