I have CM7 unofficial port stable:6.5.8 ( [UNOFFICIAL][ROM][stable:6.5.8,testing:6.6.1] CyanogenMod 7.1.0 (Android 2.3.7) - xda-developers ) on my optimus T.
Everything works fine except for two annoying problems:
1. When rebooting, the phone will be frozen at the circling cyanogen animation. I will have to disconnect the battery, put it back, tun the power on and it will boot correctly.
2. When [1] happens, all my widgets will be replaced by the "problem loading widget" boxes.
Some details:
a. [1] doesn't always happen. Generally if I reboot right after a successful rebooting everything should be fine. But if I reboot the phone after keeping it on for several days, it will always hapen.
b. [2] always and only follows [1]. (When [1] happens, [2] always does. When[1] does not, [2] never.)
c. I have link2SD installed and I do have several apps/widgets on the ext2 partition on the SD card. But [1] and [2] keep happening even when all my widgets in use is installed in the internal memory.
d. By rebooting I mean reboot from the power button menu. I never remember to try to turn the phone off and back on.
e. switching to different launchers does not help.
Any advice?
Some details:
Any advice?
