doctorlove316
Retired Moderator
Is there any way to get a link to the direct download? I mean, the downloader is nice, but I haven't owned a windows machine in ages.
Did MyDroidWorld's links not work for you? Worked fine for me.
This is correct but if you want to start themeing again, you'd have to download a ROM that deodexes your system first or you'd have to manually deodex.
I have a pretty stupid question. I have dL both the 2.3.13 system only , the .604 sbf , and they both came in a zip file that i could unzip to C. this file came in a way that i cant open it without some other sort of program. How do i open this file ? I used the megaupload to DL it. Also i DL the file AVL had , the direct download , but havent extracted the Droid x files out of it . I have RSD lite already , so do i only need to extract the DroidX files and Droid X C&D this? or what?
Have you upgraded to the OTA?
If so, you might as well delete the older (604) sbf and there's no need for the OTA system-only sbf anymore.
If you haven't upgraded to the OTA then you can keep them all, depending on what you want to do.
To use the sbf, open RSDLite 4.8 (for the newest sbf) and browse to wherever your sbf file is and then run it.
I cant seem to get the file to complete download, download keep stopping, guess the site getting hammered. Ill try later, hope it doesn't get before I can get it down.
would someone please tell exactly what this will do? I am running 2.2 OTA and I have rooted using the "one click" method. Will running this take me back to 2.2 OTA factory state?
This is what's used by Verizon to fix your phone. If your into flashing roms and stuff and mess your phone up u can flash back to stock 2.2. So yes if you use this it will return you to stock and should delete everything from your phone.
Sent from my DROIDX using Tapatalk
i understand it will remove all the files, but will it also "unroot" if u are rooted? do i need to uninstall anything prior to flashing (i.e. root programs like superuser or root explorer)
thanks...
It will unroot no need to delete anything. Your phone will just like it came out of the box with 2.2
