2013 Update 45.621.10.MB810.Verizon.en.US
sd_shadow
376
4
don't use rsd lite if phone is flashed to a non verizon carrier
don't install bootstrap on liquid rom, use reboot options to reboot to recovery
then you could just restore the nandroid I made of the 45.621.10 update, just follow my restoring nandroid instructions
Sent from my XT862 using Tapatalk
oggie7797
16
Hello again shadow and sorry for being a bother again but by any chance do you know if framaroot will work for the dx2 mb870? I was wanting to do it for my parents but if the only method is by burning files onto cd's and all that nonsense then i wont bother. Thanks again for your time
sd_shadow
376
4
No framaroot does not work with DX2, but the magic md5 method is a little easier with the DX2, because it has a fastboot option see [How To] Root 2.3.5/1.3.418 Magic MD5 Method
dariem
Hello every body,
I received an Droid x phone (MB810).
I recharged battery outside.
I has bootloader 30.04 version.
Phone was stuck in system recovery menu.
I downloaded .621 sbf and
I got in bootloader menu
I successfully flashed it using rsd, linux and livecd
same result - stuck in system recovery menu.
I do not know to restart it normally.
I need help step by step.
Thank you.
dariem
Thank you for the answer.
I used factory reset and also cache wipe (these are in system recovery menu).
I also restarted two times....
After each above it restarts in system recovery menu.
Is it necessarily to bring this MB810 in Verizone network?
Thank you
Vaibhavsoni9806
