anon(335536)
Re: [ACS][ROM] Leaf Rom - 0.1
It roots the phone for you as it updates the rom image. No need to root first.
I can't wait to try this out. My replenish comes in the mail tomorrow...I left my evo for the pixi.....and now I'm coming back to android. Has anyone had any success overclocking the replenish and getting it to run flash? I would think this is possible since 800mhz is sufficient for flash.
Maybe another dumb question, but I'm gonna ask anyway.
Now thay this has rooted my phone, is it possible to install any other ROMs, or is this currently the only ROM out there that will work on this device?
Example, I hear a lot about cyanogen... is it possible to loads that on a Replenish (or would I even want to)?
Hey guys thanks for the custom rom. Would it be possible to incorporate ad hoc support into the rom kernel (if thats possible i'm somewhat of a noob). I did manage using the instructions here to get it to work on the default system but was wondering if you could incorporate it into this rom
Shabbypenguin and the Android Creative Syndicate
are proud to present to you
Leaf Rom
0.1
Alright lets get to the nitty gritty of it all, this is the thread where all 0.x-1.x versions will be released, as it stands right now this is nothing more then just a glorified stock, but its better then that . deodexing the rom allows for easier themeing so i want to see some creative **** start to flow in.. yall dont want me making themes... anyways down to the goods
Changelog:
0.1
- - Custom bootanimations (sorry guys my graphics guys didnt have the time to make one for yall's phone.. and rather then putting this off i figured you would find one you liked ..)
- - Maximized Media scanner speeds
- - Changed out some of teh apps for slightly better apps
- - removed sprint id and base launcher, included now is go launcher. a feature rich launcher with all sorts of cool things (and themes)
- - Removed RescueStarter and RescueServer from the phone.
0.1
- - Now has the latest in malware protecting (yes even the gingerbread malware apps)
- - Sped up media scanning
- - Added GPS tweaks
- - Added ad blocking hosts file
- - Enabled ADB on boot
- - Increased max window manager events to 60 (smoothness increase)
- - Several other build.prop tweaks
- - Deodex'd
- - Zipaligned
- - Bloat removed
- - Pre-rooted
- - Enabled stagefright
Ok look i know yall are getting the update today and all that and so it may seem like this is kinda pointless, but firehak was nice enough to get me a copy of teh update (ill post it here in a min)., but alas its just like teh prevail and its filled with patches.. so that mean i need some brave person on stock to update and snag the base files for me.
now im sure some of you are prolly wondering what Rescue server and rescue starter are. well hidden away on the prevail i came across some interesting code for it, as it turns out its a program developed by logmein for sprint. for anyone unfamiliar with logmein, its a remote access company.
now look i understand there is porlly a 100 ways sprint can access the device and do what they want when they want. my only question is, do they really need such an obvious show of it? its constantly running (dont bother checking "running services tab" using adb shell or terminal emulator type in the following:
pidof RescueStarter
if you get a number then tada... yours is running . so back to what i was saying, does sprint really ned this process running in the background? i say nay, phones already have crappy life why have more crap running (hidden at that). all i did for teh rom is remove the binaries, with teh files firehak gave me i should be able to construct a odin tar for yall.
Credits:
Interdpth - For making root possible
ACS - For being a kickass team of like minded devs/themers/people
to all my beta testers for beta testing and risking their phones
Rodderik - for teh malware patch
k0nane - for so much help along the way
Firehak - For just being an awesome guy
