Re: APN Settings for Internet and MMS for Straight Talk Huawei Ascend W1
PLEASE DON'T GIVE UP!!!
After many days, I managed to setup my
MMS APN using the
wap.tracfone extension. This APN setup also allows browsing to be smoother. It does not take long as long as you follow these steps:
1. Access this website for the latest list off MMS APN and data codes:
Updated: How to Setup Straight Talk & NET10 Data and MMS on Android, iPhone & Windows Phone | Prepaid Phone News
2. From your phone's Homepage, go to Settings > Celluar > Data Connection. Set as off.
3. Scroll down to the two (2) buttons labeled "edit internet apn" and "edit mms apn."
-- If these buttons read "add internet apn" and "add mms apn," proceed to step 5.
4. Under each, select the
Trash Can icon, deleting any existing internet apn or mms apn.
5. Back (<-) out of your Cellular settings and scroll down to network settings.
-- Under "Current Internet APN" drop-box you may have a default APN listed. This can not be deleted.
6. Proceed to tap the
Add icon and setup a new
Connection Name: "Straight Talk."
7. Use the "T-Mobile SIM" setup to complete the necessary APN, Username (re-enter APN) & Port, leaving the Authentication type as NONE.
8. THIS IS VERY IMPORTANT - Under proxy server use 216.155.165.40 specified in annotation number 5 (beneath the chart).
-- I'd tried 66.209.11.33 over and over to no avail before using the above proxy and sequence of steps.
9. Save this setting, and under the Current Internet APN drop-box make sure the new "Straight Talk" APN is listed.
-- If you get a message that "The connection or sequence contains no elements." Press OK and disregard.
10. Back (<-) out to your Settings list and scroll back up to Cellular > Data Connection.
11. Under each the "add internet apn" and "add mms apn" setup the same information listed under "T-Mobile SIM."
But, FYI:
-- Under
internet apn, enter the APN, Username (re-enter APN) proxy server (216.155.165.40) & port.
-- Under
mms apn, enter the APN, Username (re-enter APN), MMSC (URL), and MMSC port.
12. Save your settings by pressing the
disk icon after entering each the "add internet apn" and "add mms apn" information.
13. Once saved, remain under the "cellular settings" screen. Scroll back up to Data Connection and set as ON.
14. Return to the Homescreen, and power off your phone.
15. Once you've rebooted, ensure that your Data Connection is set as ON and test by:
-- Opening your web browser.
-- MMS yourself a picture or video.
FYI - To avoid having to download MMS messages, under Settings > applications (swipe left or right) > messaging. Set "Automatically download MMS" to ON.
