jrapp
Active member
Yeah I like the InnoII Combo. Active will probably be just as good.
Just got the Inno Active. Fits great. Not much added bulk (some, but not too much). Seems very precise as it should be for $30.00
I had the people at best buy put mine on and it looked very simple. Just wipe it clean with a microfiber cloth. Then apply the spray and position the shield perfectly on which isn't too hard. Then just squeegee it out. And I was playing with my phone 5 mins afterwords. How do you like the car mount? I have been trying to get one
Does the case feel the same as the backing on the battery door? Does the case slide in and out of your pocket easily? Very interested in picking this case up today...your help would be much appreciated. Thanks.
do you have the silicone case as well?
if not, how much room is there in the pouch with a naked Incredible??
Wheres that Seidio guy on here that posts sometimes??
can you describe the difference between these two Seidio cases??
Innocase II Surface, Black For use with HTC Incredible
Innocase Active For use with HTC Incredible - Black
i get that one is 1 piece and the other is 2 piece but is there a size difference too? etc etc
The guy you are looking for is SeidioSeidio. Basically one snaps together top and bottom the other goes front to back. The active case is also a bit bigger case from what I can tell.
I just got my Innocase II yesterday. I have been rocking these on my devices since the days of my BB Curve and they have never failed me.
I just received my DInc yesterday, and I have the Amzer Argyle-patterned case. Its made of a tough silicone material. Its not a bad case, and it fits the phone well. Adds a little 'bulk' but with a phone as slim as the DInc, that's not a bad thing in my opinion. Seems pretty rugged as well.
However, I had a hell of a time dealing with Amzer. Lots of lies, lots of deception, and it became obvious early on that the customer was not their focus. Amazon does sell Amzer products, but their stock is hit-or-miss (part of the Amzer issues). If you can buy the case from Amazon, go for it. Otherwise, you'll have to pay ridiculous shipping costs with Amzer direct, and deal with their terrible customer service.
