I'm so scared to leave my aim messenger logged on because it pretty much swallows my battery. Which ones have you had good experiences with?
Sent From Tapatalk.
Sent From Tapatalk.
I don't know.. I'll asked Steve Jobs. Lol.So how does apple do it?
Sent From Tapatalk.
BeeJive or Trillian... Both use push notifications and handle all of the major IM protocols.
Seriously though - Personally, I've yet to hear of anyone that use any applications that is required to be constantly running in the backgrounds... for notifications to say that it doesn't use a lot more of their battery power. However, I stand corrected if that somehow could be proven.
You mean like FB for android.Push notifications. While just idle in the background, any IM client that uses push will have a very minimal effect on battery life.
Trying to SAVE battery power - is like putting band_aid on a big cut. Any application that runs in the backgrounds will always require more battery power. So, technically finding an instant messaging app that won't eat the bell out of your battery - isn't possible.
Note: Unless you turn all notifications off.
