Bonsai v4.0.1 based on Froyo EC05!
Status
Not open for further replies.
bdog421
61
I was using true blue's method over at xda because it seemed the easiest and most legit... well whenever i boot into whatever mode by holding camera, vol down, and power all at the same time I can't get it to install zip or select any of the options... its blue of course cause it is still stock
Read more is what I suggest;-)
This is the clockworkmod you want if you have an epic4G and want ext4[MOD][One Click Root] Clockwork Mod version 3.0.0.5/6 - UPDATED FOR EB13! - xda-developers
Hint; If you have bonsai or SRF on your sdcard, once it converts you flash your rom and are good to go, no need for the dual rfs/ext4 kernel. Also instructions for installing cwm3 are here on AC. I encourage you to read more before jumping straight into ext4.
khughes6
59
after re looking at the directions I remember I didn't do what I said earlier, I ran the .bat file because i'm on windows... I extracted the files into a folder but then still had to double click on the one that was initially downloaded to find the .bat file because only .sh was available. When I did that the black box showed up and I pushed any key to continue, then it said the .arm file was missing
jerseykat1
175
4
So i have tried syndicate rom frozen all versions to date, and bonsai 4.00. So far This rom has worked without error since installation. I cant say the same for SRF, SRF is a good rom but it has its flaws.
I am using the baked snack kernal 1.2low with this rom.
fab5valentine
65
4
To try the Bonsai ROM, if I'm currently running Baked Snack 2.3 EB13 ROM with 1.2low EC05 Kernel. Do I just flash Bonsai 4.0, or do I need to insatall the EC05 modem with Odin?? Thanks!!!!!!!!
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
I believe Bonsai 4.0 actually has the modem update built into it.. The install script will automatically detect if you need the modem and update it.
a_c_s
157
4
But if you liked the BS kernel, you'd have to reflash that after installing the Bonsai ROM because Bonsai has it's own kernel... just fyi...
a_c_s
157
4
For 4.0.1 is this a simple flash over 4.0.0? Will it retain all data and system settings, or will portions/all be wiped? I was on the Bonsai site and unless I was looking in the wrong place, did not see anything re install instructions...
jjayr41
63
Yeah just a simple flash in CWM...just like the 4.0 install, all my data and settings are retained =)..only thing I had to restore was the clock on the notification bar.
Reactions: a_c_s
freality
Active member
Aug 12, 2010
31
This rom has been great. One minor nitpick is the default internet browser force closes. Not a huge deal since I use Opera mobile, but sometimes my searches try to use it.
Here's what I get: "Sorry! The application Internet (process com.android.browser) has stopped unexpectedly. Please try again."
I've tried clearing data to no avail. Anyone else run into this?
EDIT: Fixed. Root Explorer to rename my data/data/com.android.browser folder, reboot to let the system recreate from scratch, default browser now works.
a_c_s
157
4
I just tried my stock browser and it appears to be working fine... I also get a popup box whenever something needs to launch a browser, giving me the options of stock, opera mini or dolphin... you can check the box and make one the default, but I prefer the popup, as different sites work better in different browsers...
Status
