Can't use my phone Need Help!!!
Nov 1, 2012
20
So I recently tried to install a Jelly Bean ROM so I decided to flash a new kernel by komodo and ever since that I can't start up a ROM because I get stuck in a boot loop. All I have access to is recovery and HBOOT. When I'm in HBOOT this is what I see if this might help you. I'm also on recovery v2.2.2.
*** TAMPERED ***
*** UNLOCKED ***
JEWEL PVT SHIP S-ON RL
HBOOT-1.19.0000
RADIO-1.12.11.0809
OpenDSP-v29.1.0.45.0622
eMMC-boot
Aug 9 2012,15:14:25
Please if you know what's wrong and can help me reply or pm me. Thank you.
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
I see you started another thread,,Anyways , lets run a RUU, If you have the .exe, make sure you have the latest DRIVERS installed on your pc. Boot the phone to recovery with the phone plugged into the usb and and run the .exe
Make sure you download RUU_JEWEL_CLICS_40_S_Sprint_WWE-2.13.651.1_Radio_1.12.11.0809_NV_SPCS-2.45_003_release_277028_signed.exe
BlackHawkA4
Drop the Bag
Sep 1, 2010
2,192
74
*** TAMPERED ***
*** UNLOCKED ***
HBOOT-1.19.0000
RADIO-1.12.11.0809
eMMC-boot
Aug 9 2012,15:14:25
If you made a backup flash your backup and the phone will work.
Otherwise or even after you do that you need fast boot to flash the boot.IMg. the boot doesn't flash with thar hboot.
Nov 1, 2012
20
I went into recovery but it said it wasn't connected even though i had it mounted, was i suppose to do anything specific in recovery so the exe can recognize my phone.
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
do you know to pull the rom.zip from the .exe?
Edit: do you have sdk or at least fastboot and adb installed on your pc?
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
ok plug your phone in and reboot it into the bootloader, when it does make sure you have fastboot usb highlighted, if it is then on you pc , hold down the shift key right click on the folder you extracted to your desktop and click on open command prompt from here
In the cmd window type this fastboot oem lock
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
yes go into recovery and choose mount usb storage and copy the PJ75IMG over then choose reboot to bootloader. it should find the zip you just put on there and ask if you want to update, should be volume up for yes
cloudsofmana
