Charging Issue
Fazulka
135
10
Weird problem with my phone. Last night it would not charge on my car charger (Motorola brand) or the charger I normally use at home (RIM). Not sure where the charge is that came with the Hero so I didn't try that. On the RIM charger it got stuck in a loop where it kept making the dieing battery noise, but never showed it charging. I then plugged in via USB to the computer, and it charged fine. I even tried charging from the PS3 and it charged fine.
Anyone have an issue like this? I have option 3 installed (It is great, like getting a much newer phone).
I just tried a Motorola wall charger and it worked, but it took longer than usual before the phone realized it was plugged in.
If it is a problem with my phone should I run the 1.5 RUU before going back to Sprint?
Thanks!
mountaindont
Active member
May 17, 2010
37
it sounds to me like your chargers are broken, i dont think its a software issue. also take note that HTC does have their own little miniusb thing with the slant down the side. do your chargers match?
rholme
