are there any more major updates in the works, or can we only update now from the nightly builds? I installed alpha 2 and have had a great experience with it but I am hesitant to mess around with the nightlies
I'm currently running the nightly dated 4/18 after updating several times beginning with 4/4, my initial install.
Before you do anything, make a full backup with ClockworkMod so you can restore if anything goes wrong.
I updated to 4/28 and it didn't seem like Wifi was as strong, may have been my imagination, so I flashed back.
Here's the process I used for updating and going back. I didn't do step #1 all the time after I felt I knew what I was doing, but it's an important step for any beginner.
1. Make a full system backup using Clockwork Mod
2. Do not reboot system after backup is finished.
3. Wipe the Cache from within ClockworkMod
4. Go to ADVANCED and wipe the Dalvik Cache
5. Go back to the main menu of Clockwork Mod and select INSTALL ZIP FROM SD CARD
6. Select the new nightly or (if you are going back to a previous release) the old nightly.
7. Install it
8. Reboot system
