Worked great in safe mode and after restart it started working again. It's like it's playing hide and seek with me. LolTry this in safe mode , might have to stay in that mode to test it out to rule out any 3rd party apps
I'm trying to avoid both options. It's working for now. I'll see how long it last . If it goes out again I'll try a factory reset. Thanks for the help.I know you'll hate reading this but Honestly a factory reset may be your only option since you now know the hardware is good in Safe Mode. You can still do a backup and restore just don't restore any system settings. Home screen settings should be fine to restore.
OR
Since you know you have to factory reset maybe still pursue a warranty replacement. Just let them know you've tried everything under the sun and they typically don't fuss about and just process the warranty replacement.
Either a app is causing this or maybe your carrier having issues on their end might want call them , your on sprint if I remember correctly?Worked great in safe mode and after restart it started working again. It's like it's playing hide and seek with me. Lol
Ok...
Glad you got it figured out.I just came from the Att store and apparently it was adguard . Once she had me uninstall it data started working. Ive had adguard since I got the phone and never had this issue, but whatever it's working for now. Thanks for all your help everyone.
I got mad at the lady. I thought she was dumb. I never had this issue with adguard. LolThat's weird. I also use Ad Guard(plus 3 other as blockers . I don't know if that's overkill) . I've not had this problem. Yet.
Was just gonna say this. Reset network. Can also wipe the cache in recovery modeTry reset network in settings under connection
Hi, don't recall giving that adviceMan am I glad that I found this thread. I did an app optimization under Galaxy Labs and hosed wireless and cellular data. Tried the typical stuff. Nothing. I didn't have the adguard app, assuming that's what everyone in this threat was talking about, but I did have 'dns.adguard.com' set up as a Private DNS. I removed it and voila, data was back.
@mustang7757, If I remember right, i got the 'dns.adguard.com' recommendation from you in another thread. Do you know anything I can do to allow it to work again? I just tried it and had to turn it back off.
Thanks in advance.
Jim
Your welcome!You're right. I'm not remembering correctly. I'll try your recommendations. Thanks!
