Dreamliner330
People are stupid. They buy what gets advertised to them. Samsung and Apple are marketing kings and dominate market share. Coincidence? No.I don't understand Samsungs logic with this phone.
Enter the Galaxy Note 4Why the compromise though, the only thing "premium" seems to be the metal ring. I'm sorry, but compromising specs for better build quality is not premium. In my mind premium is uncompromising.
I don't understand Samsungs logic with this phone. Samsung most likely considers the iPhone a mid range device because of specs.
They don't seem to understand that the iPhone handles iOS with the same speed and agility as Samsungs Flagship devices.
The Alpha would have been an Amazing phone if it had 1080p and 3GB Ram. I went into AT&T today and played with this device.
As usual, touchwiz lagged and choked in certain areas.
Why does samsung not get what people want? Take the alpha and put flagship parts in it.
I want the 16MP like the Note 4.
I want the 1080p screen.
I want 3GB Ram to smooth out touch-wiz poor coding and extra bloat.
Wake up samsung. geez How can a company this big be this clueless.
The executive that woke up one morning and said "hey, lets make a near exact copy of the iPhone with a 4.7 display, that is absolutely gorgeous and appears to be the most high end device we've ever made" but lets just throw some low end parts in it and see what happens".... -needs to be fired.
WTF samsung.
Just saw it at AT&T: nothing special.
Seems just like a smaller S5 with a worse screen, no ip67 or removable storage.
Furthermore, it is approximately the same price as the S5.
Samsung won't sell a lot of these...
Just curious. Do you mean that you saw a Galaxy Alpha in a U.S. store?
Sent from my Samsung Galaxy S4 (SGH-I337) using Tapatalk Pro
WTF samsung.
I'll bet that there are =zero= customers who will actually buy the Galaxy Alpha and then return it because of its "low resolution" screen.
Lackluster Specs? Other then the 720p screen what is different between it and the S5? S5 and Alpha both have 2GB of RAM, and Snapdragon 801 CPU. The other difference is memory but Alpha has 32GB internal with no expanded memory vs the S5 with 16GB but with expanded memory ....
Yes, it is in all Att stores
Exactly. Lackluster? I think you need better vocabulary my friend! I am getting this phone Monday not many good phones that are 4.7 now days
Well if you claim that the display of the Alpha is better/sharper than the S5, then you're having some severe eyesight problems. I recommend you do a check up.
Yes I "happened" to try them out under the exact same conditions! Same brightness settings, same screen mode (adaptive, standard, RGB etc), and of course using the same websites and texts to compare the two. So... I have done my homework correctly!I was going to say the same to you, but I tend to be more polite than that. All I can tell you is that I adjusted the brightness to make the two phones as close as I could (did you happen to try that?), then I got to the same screen -- the settings screen in list mode (did you happen to try that?), and I thought that the Alpha's text was noticeably crisper than the S5's text. I held the phones right next to each other, at a normal viewing distance. I thought there was a noticeable difference for the better with the Alpha's screen.
That said, please note that I have talked about the "crispness" of the "text" at "normal viewing distances." You might find other aspects of the screens to be better in the S5's case, but I'm simply talking about equivalent "text" against equivalent backgrounds.
