doogald
Trusted Member
It's starting to look that way. It wouldn't surprise me one bit if the Maxx didn't get another update.
Since both Motorola and Verizon just updated the 2012 Droids to KitKat, I think that's unlikely. The update is coming. We just had some unfortunate bad luck.
I just wish they would've stopped before they changed the icons from blue to white. I can't stand the white icons. I can't tell if I'm connected to wifi or not. Is there an app out there that will let me change those icons back to blue like they should be.
A Google Engineer Explains Why KitKat Has White Status Bar Icons And Only Shows Connectivity In Quick Settings
I've seen a rebuttal from somebody who called that reasoning BS. I should have kept a link.. it was a very experienced Android developer who gave plenty of reasons why it could have been tweaked to completely eliminate and performance or battery issues. I think that the reason that people were confused about colors (and Google didn't want visibility to the rare Google Play connectivity issues) was the real reason.
By the way, I find the "blinking lights" to be more than "visual noise". Even Apple shows network activity on iOS - when you have network activity, there is a visual indicator of network activity. I'm glad that Moto/Verizon didn't drop that for the Droids when they changed the color. (By the way, I am fine with white icons so long as there is a gray when there is a loss of connectivity. That's still done with the Bluetooth icon, so clearly Google is ok with that as a visual indicator theme.)
So somewhere there was a gap and the team saw that 4.4.4's release as an opportunity to delay any further.
The simpler explanation is that Motorola decided that they didn't want to do two updates, particularly because the 4.4.4 update fixes a fairly serious security bug, They pulled the update for the Verizon and AT&T Moto X as well. Now they will have to so a second update for the unlocked and Sprint Moto X.
FYI. Your theory is completely wrong in regards to the Moto X and MAXX argument. Moto X and MAXX come from the same exact update and are exactly carrier driven as well. Which means, Verizon did approve Moto X updates, but not MAXX updates. And that may very well be due to exclusivity.
The Droids do have different software, particularly the Droid Zapp features. It's possible that Verizon wanted to add or change the pre-installed software set on the Droids which were not on the X. I have a theory, though, that Verizon really wanted the 2012 Droids updated to KitKat before the 2013 Droids received 4.4.2, and that was what caused the delay.
